tilt and shift does not work at my camera
Hello.
I have read that the tilt and shift function at VrayforC4D is fixed and should work. I downloaded the newest version today (v5.19.24), but the tilt and shift function does not have any effect at my final render.
I can see that the camera sector changes at the preview window, but when I render the final image, nothing has changed. Also at the V-ray VFB, the shift has no effect at my picture.
Am I doing something wrong or is there a bug?
I would be very happy to get some help.
Thank you,
Petra
Hello @Kallisto ,
Have you changed the camera type in the Overrides tab of the render settings? If that is the case, please note that this bug has already been discussed here on the forum and it has been reported to our developers for fixing (bug ID: VC4D-698). I will let you know once we have updates on the matter.
The tilt and shift work correctly if the camera type is set to “Standard”.
Hello Aleksandar.
You are right, the camera had been set to pinhole in the override tab. When I change it to standard, the shift works as expected.
Thank you very very much for your help!!!
Regards
Petra
