Hi guys,
in the future will be planned to Tilt shift option in the camera?
You can already do this with Cinema’s camera. Set your cameras P rotation to 0 and then use film offset Y to re-center your shot.
-Shane
if you use max 2016 or above, check this out
no, this is section forum cinema 4d, thanks ![]()
Are you just trying get straight verticals or the tilt shift blur effect? What I suggested will give you straight vertical lines. There is also a tilt camera set-up with Xpresso in the content browser.
thanks, I had never tried ![]()
