Updated to RC9 this morning so I could disable adaptive light sampling as it was problematic in my current scene. Now the tilt & shift rollout no longer does anything for any Corona camera in the scene.
It appeared to function normally until I isolated some geometry then it seemed to break the tilt.
This occurs when using Max’s physical camera as well. Once I save and reopen, the functionality returns.
This may be a Max issue but this is the first I’ve experienced it with the only change being the update to RC9.
Could be related to the other reports that whenever the camera is hidden, the tilt and shift stops having an effect - my guess is that isolating objects also hides the camera (unless you include it in the isolation?)
Ah, this could be the case. I have my cameras hidden globally under the Display rollout. Turning them on restores the functionality.
This should be fixed in RC10 - I tested various ways of hiding the camera (isolating objects, hiding it in the command panel, etc) and could duplicate the bug in RC 9 but now everything works as expected in RC10. If you have any ongoing problem, please start a new thread with a detailed report! Thanks!
