Time scale and steps per frame
HI manual says if time scale is 0.5 spf should be reduced by 2. We are currently simulating at 2 stp an explosion and want to reduce speed by 33 times but spf cannot go lower than 1. what should we do?
Hey,
33 times slowdown is near impossible to retime. Realistic values are about 10 times speed reduction. Your best shot would be to try and use Time-Bend resimulation instead - Chaos Docs.
Hope this helps, but I think you would first need to increase the scene scale and get a slower base simulation, and just then re-time it when the slowdown would be no more than 4-5 times.
