My timeline is locked because I accidentally moved the right marker completely to the left. So it is now on top of the left one.
The time slider won’t move anymore because the range is 0.The whole animation editor is sort of grey out.
You’re right, it’s a bug. I think this wasn’t possible before, but it must have regressed with the UI rework for 2.0. It seems the only way out of it is to load an earlier .vantage file. If you’ve already saved a .vantage file in this broken state, you could open it with a text editor, find “animation_trim_end” and set the value to 0.0
You can also try to change one of the cameras’ duration as you resize it with the mouse a bit. This changes the end trim position too and get you out of the “grey out” state.
