Tin Ceiling
I’ve tried googling around a bit, but I can’t seem to find any. Does anyone here have, or know where I can get some tin ceiling prints that I can use with VrayDisplacement, or know how to make them easily.
Thanks :slight_smile:
my sugestion is to model one modul, then render the Z-depth and use it for the displacement :wink:
Do you mean something like this material? I made this using a simple displacement map. Let me know if you are interested.
Hey timmatron, really nice material btw !!!
i thought it was this tin ceiling ( google)
model a section yourself. then add a uvw map then using texporter there should be an option which i think gives you the equivilent of a zbuffer on your model.
OH! Hehehe, I guess I was WAY off! :sweat_smile:
Next time I should do my research first. Later!
Yeah, tin ceiling is the blocked ceiling pattern, but that is an excellent material Timmatron.
However, while the squares like that are rather easy to model, I was looking for something a bit more ornate, that would be outside my modeling skills. Hmm, thanks anyways guys.
yes…timmatron…now you show, now you have to share ! :lol: :lol: :lol:
hehehe…Olivier is right…I’d like to see that displacement texture as well, timmatron :smile: …that’s a really good material :smile:
paul.
tin ceiling…
I seem to remember seeing some very high resolution photos on the web of a very ordinary tin ceiling product. You might do a google search of the tradename (now bear with me) “lincrusta”.
Phonetically, it’s “lynn-crust-ah”. It was/is a very common ceiling material type. It could also be a company name.
Give it a go. I’ll bet you can come up with a bunch of vendor/supplier catalog images that would be useful as bump maps and displacement map materials.
Ok, here is the map…its really easy to make. Somebody else could make one thats better than this but it works ok. Just add this in displacement & use about 1". I also use a shift amount of -1" to keep it in place.
Then just play around with your glossy. I set my to about .9 and seems to work ok.
thanks for the map timmatron,
hypnotic…
must look away from screen… :wink:
