Hi all!
Discovered an interesting thing, if the diffuse map to use a bitmap with obvious noise, the smoothing error occurs.
To avoid this, use “Summed Area” filter in the bitmap parameters.
The whole filtering in corona is somehow weird… I don’t know maybe it’s just me but it feels somehow wrong, I’m pretty busy right now so can’t do a proper tests but image filtering, texture filtering and when it comes to bump mapping it’s all just weird… Anyone experiencing some stuff like that compared to other renderers?? Or am I seeing stuff?
LOL
i’ve read if you use the summed area filter your render time will double, so it’s not a big deal.
My tests have shown, this is a wrong statement:
http://forum.corona-renderer.com/index.php/topic,316.msg4726.html#new
will test it also, this is weird because the other guy did also a test and the differente is huge.
Anyway thanks for the tip !
Summed area seems (to me ) to have a bigger impact on the REnderTime using Scanline and Mentalray, but the textures looks better.
The first thing i´ve learned using Corona is to put Blur texture filtering on ZERO and check summed Area. It solved all my problems with textures. I didn´t notice a great impact on render time… I am not sure.
spoiler alert: in time I’ll implement my own bitmap texture with an optimized sampling/filtering, the max one is always slow.
Max is about to become a Corona plugin. ![]()
