little issue - could it be possible to get one task bar note only, also if several Rhino tasks are opened?
(I’m in the middle of tight project and found no time to install the latest preview version. But I’m very curious … .)
You can disable notifications for preview versions in the about window. Don’t know why the notification icons don’t disappear correctly. If you move the mouse over them, they disappear on my machine, at least.
I’m not sure you understand the situation - the problem is every Rhino task create a new notification symbol and since I’m working on several Rhino task at the same time, I get so much notifications. If I find time I will shut down all Rhino tasks and install the latest preview. But one notification symbol would be enough.
