Thank you Tom.
HLeandre, NP !
DOF
MultiScatter + FR-MTD
Alpha4 / max 2014
PT + HD / SUN+SKY
pt smp = 4
light smp = 2
1600x1200 / 1 hour = approximately 200 samples
When it became pure, I do not know, I was not at home…
Alpha5 rc1/ max 2012
PT + HD / SUN+SKY
pt smp = 4
light smp = 2
1600x1200
PT + HD / SUN+SKY
pt smp = 1
light smp = 1
1600x1200
PT + HD / SUN+SKY
pt smp = 1
light smp = 1
1600x1200
CORONA Renderer Alpha V7 final
11 000 000 poly in scene (disregarding multiscatter inst.)
for test uses:
4 hdr Peter Guthrie, iTrees 3d Models, multiscatter, 3dsmax2012
Intermediate pictures to see rendering time
See HiRez - Corona aV7 (2014) - 01 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 02 by TOMYODA on DeviantArt
See HiRez - TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 04 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 05 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 06 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 07 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 08 by TOMYODA on DeviantArt
See HiRez - Corona aV7 (2014) - 09 by TOMYODA on DeviantArt
Those pics in last post, are just incredible! Top work.
romullus,
Thank you!
WOW!.. just WOW!.
I think i really need to buy more ram XD.
Beautiful photos. Especially love the macro shots. What lens did you use? ![]()
borisquezadaa
Thanks!
Yep, really, much ram does not happen!))
512 Gb - Good choice ))
And if it is serious, the crown perfectly works with heavy to scenes.
At me in general what errors it is not shown, absolutely there are no the departures, which I caught all bugs, have corrected still in alpha 3.
maru
Ahaha )) Thank You!
I use for not high dof - 80, 135 mm x 1.6 crop factor,
For high dof - 255, 400, 600 mm x 1.6 crop factor
ps. sorry for my English.
I’m just curious… does google translator appends the “PS: sorry for my english” sentence automatically?
I’ve seen it so many times…
Keymaster,
No, it is my initiative)) I simply do not know, whether understand me or not, and Russian people are very polite! ;)))
Great thread, especially the displace and DOF testing. Thanks Tom.
modern_babylon,
Thanks men!
I am glad to be useful.
Has noticed, when the sun shines almost in camera, are born fireflys
lowPost:
See HiRez - Corona aV7 (2014) - 10 by TOMYODA on DeviantArt
Settings for Landscape renders :
PT -
dof off:
GI\AA - 4(or 6)
Light Samples - 2
(There is no sense to increase options when the similar exterior is visualised.
It is a lot of objects, many small details, shades and light is allows to lower options.)
dof on:
GI\AA - 1
Light Samples - 1
HD -
Precomp - 12
Record - 512
Dof -
F-stop - 1.2
Shutter - 125
Sensor - 80,135,255,300,400,600,800,1200
ps. Look my tests in LJ on a tag - corona render
http://tomyoda.livejournal.com/tag/corona%20render
I think it doesn’t make sense to use GI/AA 4 or 6 when DOF is off and 1 when DOF is on. You should use about 16 when DOF off and at least 4 when DOF on. On the other hand, this isn’t so important if you have lots of time to render. I also wouldn’t recommend using HD cache for exterior shots. PT+PT should work fine amd you don’t have to waste time for HD cache precomputations.
What kind of camera are you using sir ![]()
is it corona hahahah GREAT PHOTOS
maru,
I should not use what or options GI under any requirement.
Ondra only recommended options from which it is possible to make a start, and it is necessary to study and be arranged under a concrete situation further.
In case of a considerable quantity of a grass and trees, you will not see differences between GI 4-8 and 16, it is possible to take a magnifier glass and to find two pixels which differ absolutely hardly hardly…
(It occurs because trees and a grass is much, many small details, with shades, penumbras and light, all distinction is lost in them)
But will increase time renders… When it is used DOF, it is more appreciable.
As, why I cannot use HD for external shots? After all I used, means it is possible! ![]()
And how can HD be vain? After all it helps primary GI! And about what vain time there is a speech? HD has occupied time - to steam of minutes. (For a final picture at 2-10 o’clock, HD 2-10 minutes that does not mean!
The theory it is good, but practice is better, and ideally theory + practice.
I have deliberately put low options GI/AA (not from misunderstanding of options), I have spent a lot of time for tests to choose these options.
If the result on 99 % is identical, why I should increase options, and as a result time?
Sorry for my English
(I hope you me understand)
post: only contrast in CFB (corona frame bufer)
Find 10 differences and tell to me about them … ![]()
At what options GI/AA it is pleasant to you more?
With postprocessing in LR
I have created presset on the first picture and have applied it to all the rest
What variant is pleasant more, light or dark?
ps:
I deliberately show so much pictures in this post that you could compare a pure picture and to postprocessing at different options GI/AA
That you could see as quality changes at different options, or does not change.
