Tomemap management in V-Ray Bitmap Shader
I had a greate Featurerequest:
Very often, when images are used, they have to be adjusted a little in color, saturation, or orientation.
This always has to be realized over several levels through the use of shaders.
In Thea-Render it was extremely easy.
It would be an enormous time saver if you could incorporate the following into the V-Ray bitmap shader:
Thanks so such If you could realice this.
Ronald
Hello @Kissling ,
You could adjust the hue, saturation, contrast, etc. of an image using the native Cinema4D Filter shader.
Hello Alexandar,
I know this :slight_smile:
But rotating a picture is not possible!
And this is needet verry often.
It is the combination of ALL this possibilities.
Ronald
Probably if you rotate the texture using the layer shader and you bake the results it will work.
plus one… a direct function for example rotation, without baking would be great..
For now, this won’t be done, as if we implement it, it would cause interoperability issues between in V-Ray for Cinema4D and other V-Ray integrations.
Thanks for the understanding.
