I’d like to suggest the option to group operators in the Tone Mapping stack.
This will allow users to compare different options of multiple operators by just checking on and off a certain group.
Ideally, if there’s a way to go back and forth from one group to another (when you turn on one group, a second group switches off automatically), that would be great.
As an option, it would be great to have the chance to save VFB settings directly in the current presets menu. Of course, with the possibility to change the order, delete, and modify them.
The effect of combination of multiple different operators can be done through VFB History, with enabled original postproduction.
As I understand, the feature request is to be able to enable/disabled multiple operators at once, right?
I don’t think this would be the best way to cover the intended behavior, but VFB 2 is in the plans and feedback on the UI/UX is welcome.
I also think over-featuring it (like being able to order operators, or group, maybe layering is the better idea, or foldering) not a good idea.
I will have this in mind for the discussions of UI/UX of the new VFB.
