Tonemapping issue with Vray 5 cpu?
Friends! It’s been a long time. I’ve missed you. I haven’t stopped using V-Ray but I haven’t posted in quite some time. I recently decided to try out VRay 5 to see if it’ll help my workflow and business.
I’m having a small issue which appears to be tonemapping or something on my renders.
I’m using Max 2021, VRay 5 hotfix 2. I’ve tested with Max 2019 VRay 5 hotfix 2 and am seeing the same issue.
My max Gamma is set to 2.2. VRay settings are all defaults.
Renders look correct in VRay 5 GPU:
And this is the result I get when I use CPU, what tiny checkbox am I missing?
Appreciate the help,
Colin
The real culprit here might be max 2021, but I can’t test, which from what I can tell is terrible, unstable, the usual. I went back and tested with Max 2019 as well, same issue.
Here’s a video showing the problem.
https://drive.google.com/file/d/1rzN…ew?usp=sharing
Figured it out, Logarithmic exposure control somehow got set in my environment settings, turning to to “<no exposure control>” fixes the issue, still unexpected behavior.
