Tonemapping not updating in IR when camera tag beeing changed
Corona v9
Hey there,
we use a stage tag alot to render a set of single still cameras. also in IR we go through the several cams by changing the frame in the timeline.
In older Corona Versions the camera tag (tonemapping) could be changed and the changes were visible in th IR immediately. Now it need a restart the IR every time. super annoying when having to adjust 10 cameras consecutevly :frowning:
unfortunately in the framebuffer the tonemapping is always connected to the camera that it was started with. this has always been this way. but now the workaround through the tag is not working aswell.
why is the tonemapping tool getting so complicated anyway? can annyone tell me why its better to have different tonemaps saved instead of just duplicating the camera an changing the tag?
thanks!
Hi there, we have this logged and will look into it.
(Internal ID=1000600659)
ok thanks.
and what does this mean? now nothing gets saved into the camera tag :frowning:
Document was closed, values won’t be synchronized.
Hi there, as a workaround, you could create multiple cameras with the settings you need and then use Cinema’s Interactive Render Region. Seems to work here. I hope that helps (for now).
ah ok, never used that before. will try it out!
please try to keep coronas usability as clean and smooth as it used to be.
thanks;)
Of course! We never plan on breaking things! We also have this logged and it will be looked into. :smiley:
