Tonemapping Order/Behaviour
If you put any operator ABOVE Aces OT - you are applying it to this image (i.e. a huge range of RGB values) - https://forum.corona-renderer.com/index.php?action=dlattach;topic=40616.0;attach=186553;image
If you put any operator BELOW Aces OT - you are applying it to this image (i.e. a “flat” image clamped to 0-1 range only) - https://forum.corona-renderer.com/index.php?action=dlattach;topic=40616.0;attach=186555;image
So it is expected that you will get completely different results.
You can use whatever order you prefer, but I would say that putting ACES OT as the last one in the stack is more correct. This way you make some adjustments to your full high dynamic range image, and clamp it to 0-1 range as the last step.
Marcin - did you watch the video?
I’m not questioning what you’re saying at all. I fully appreciate and understand that. But I would have thought that increasing the highlights value in the Tone Curve operator to a positive number would make the highlights brighter regardless of whether it was on a clamped or unclamped image.
And it’s exactly when the tone curve operator is above ACES OT that I’m having issues. As you can see in the screen recording and the screenshots in the very first post. When I have the Tone Curve above ACES OT, using minus value increases the highlights and using positive values decreases the highlights.
Surely that isn’t right at a fundamental common sense level of understanding.
It’s basically doing the opposite of what you’re telling me it should be doing. Even the tooltip in the VFB verifies this. Postive values make highlights brighter etc
It doesn’t behave this way if I place it below ACES OT, it behaves as expected, albeit on a now clamped image.
no, I did not watched the video as I checked and showed with a graph few post ago what Tone Curve exactly does. ploted curve tells me more.
Tone Curve is only usable on tone mapped image: when it adjusts highlights it does so only to a range of ~0.6 - 1.0 float with a pivot placed at 1,1 (x,y). Pivot at this point means that suppressing the highlights to -1 with Highlights spinner in Tone Curve (at ~0.8) results in values above 1.0 float to increase substantially. Hence your issues with using Tone Curve above ACES OT.
on a tone mapped image, not clamped image. clamping would be cutting or truncating values.
I meant Maru (also called Marcin)
heh.
anyway, does it clear things out?
Sure, you’re effectively confirming what I’m saying/experiencing. But Maru is effectively saying the opposite.
You’re saying Tone Curve is only usable on a tone mapped image. So below ACES OT in the stack.
Maru has said the most correct way would be to use it above ACES OT, so before tonemapping.
The tooltip just confuses things further by not specifiying either way and the tooltip basically says positive values will make highlights brighter etc - but as I’ve found out and you’ve proved, it only works that way if placed below the ACES OT in the stack.
So this is ultimately why I asked for confirmation. We’ve got the people who make the software saying one thing, and the users saying another.
Also for what it’s worth, I do expect different results from the Tone Curve dependant on whether it’s above or below ACES OT. I’ve understood that from day one. My issue wasn’t necessarily with suppressing highlights either. In fact the exact opposite, I want to bring them back. Increase them. But you can’t increase the highlights with tone curve operator when it’s placed above ACES OT, it does the opposite. It decreases them. It completely flattens them. When placed above ACES OT in the stack. Positive highlight numbers in the tone curve operator progressively suppresses the highlights.
Also if what I’m experiencing is correct, and what you’re saying is correct, then the tooltip should explicitly state that it only works as described when placed below ACES OT in the stack.
I think we are dealing with a very simple issue here, but it’s tricky to explain. I will do my best to get a proper, easy to understand answer here.
Sorry for the confusion and it seems that it would be also great to update our help guides once we have the final results!
From my personal experience, a few operators just don’t work well when used before ACES operator (or Reinhard/filmic tone mapping prior to availability of ACES):
  • Tone Curve - results are not consistent (probably due to the ‘response curve’ of ACES acting differently on different brightness levels)
  • Contrast - same
  • LUT - same
  • Saturation - this one has been wonky since day 1, it’s way too aggressive but seems to behave slightly better after ACES
The only ones that I use before ACES are the obvious ones - Exposure, White Balance, Gree/Magenta Tint. Sometimes, I’ll use Highlight Compression before ACES to increase/reduce highlights (this one is meant to work on HDR input after all).
I don’t follow the ‘Keep ACES always the last in the chain’ rule because it just doesn’t look good for some operators. Rules exist to be broken :smiley: Also, I’m pretty sure some are definitely NOT meant to be used before ACES, like LUT.
Correct, it’s very simple. You said the most correct way to use Tone Curve is above ACES. The tooltip for highlights in the tone curve operator states ‘positive values enhance them, negative values suppress them’ - but when I place Tone Curve above ACES OT and use a positive value for highlights it suppresses them, if I use a negative value it enhances them. It’s that simple.
The video I posted clearly demonstrates this.
Maybe labelling operators as “HDR” (to be used before any Tonemapper in stack) and “SDR” (to be used after Tonemapper) would be good indicator where to properly use modifiers.
Of course, for artistic freedom, any combination can be done.
Ondra effectively suggested the same, but he wanted to label SDR as sRGB which would be incorrect when full color management is implemented.
ACES Tonemapper as last step of color grading is only done in softwares/pipelines where all operators are fully HDR, like in Unreal 5 (with exception of LUT of course).
why label Tone Curve SDR if it does indeed handle hdr input and outputs also an hdr image?
grading within aces system is almost always done in one of the aces log spaces, no need for hdr tools.
edit: and tone mapper is indeed the last operation before pixels go to screen.
You nit-pick part of answers out of context, add words no one said, and I am just confused what are you trying to say then really.
Then you also write it in such weird condescending way that is meant to convey authority over the topic?
Input/Output wouldn’t be what denotes the operator, the operation mode would. Even LUT in Corona uses hack to output partial HDR data (by extending highlights, trick that Ondra copied from VFB+ plugin after many requests, as it was very handy feature).
We don’t have any ACES system, we have ACES Tonemapper, one element taken out due to popular request, operating in HDR space, not LOG. So what do you mean by no need for HDR tools? We’re not talking about any movie pipeline, we’re talking Corona Framebuffer.
Also framebuffer in Corona/Vray isn’t a color grading operation only, it’s also compositor and since it was built based on user requests, now offers hybrid approach that slowly encroaches towards “PhotoshopLite”. So Tonemapper isn’t last in order by any requirement.
I’m just not ok with misinformation.
If I’m coming across as condescending - apologies, it’s not intentional.
yes, I’m talking about frame buffer of Corona.
no need for “HDR tools”: you’re claiming that aces tone mapper is last operation only where all operators are “fully hdr”. there is no usable software manipulating colours that does that. its not very convinient to colour correct in hdr and colour grading is near impossible. who does that? all that is conveniently done in ldr, so it’s possible to see the image, see the colour curves in a display specific range (or whatever other tool). addition and multiplication is all you need from “hdr” operators. everything else can operate within displays 0-1 range.
one thing I would like to clarify, if possible:
what do you mean by operation mode"?
We looked into this and indeed the way it works is at least “counter-intuitive”. This is now logged for our devs to review and here are the further steps that we are planning to take:
  • explain the current behavior
  • share what the correct order is for these and other operators
  • feature request: mark which operators work in low and high dynamic range
(Internal ID=1177158641)
Hi Maru,
Do you have an ETA for this?
thx
Whilst we’re talking about tone mapping stack behaviour - the issue with curves at the bottom of the stack still exists too https://forum.corona-renderer.com/ Slow VFB #msg227426
Marcin is off currently, here are my points about this:
  • ACES OT is something like Display/view transform in Color Management - it is applied as the last thing, to “bring” values to display/color space specific equivalents. Regarding this, we introduced a warning message with OCIO workflow if ACES OT is enabled, as it effectively applies the transformation(s) twice, possibly causing wrong results (artistic control is nevertheless allowed and welcome). What tone curve and ACES OT (and other operators) do can be better described/understood by placing a curves operator before/after an operator, and checking the histogram to see the effect of an operator. They alter the values in a specific way. 3ds Max color management view transformation, in case of OCIO workflow, is always applied after tone mapping. So
  • there is no correct/wrong behavior. There is a known/best practice on how to do tone mapping and view/color transformation, for a broader VFX industry, but not necessarilly for Corona or archviz, at least now. I have seen people using vignette right after simple exposure, and it is weird for me, but hey, if it pleases the eye, go with it
  • Operators work on the very values that are rendered. An operator changes the values, the next operator does too, and so on. I believe there is no operator in Corona which works in a specific value (low, high) range, they work on the values that are there before applying an operator. There was just the LUT related improvement, which worked considering the values were gamma-mapped, while there are LUTs which are supposed to work with linear values, and we introduced the “linear” checkbox for this. This does not mean that LUT works in HDR and e.g. contrast works in LDR
  • The important part is the linear workflow breaking or not-breaking. Simply put, this is, if you were to put all the layers of the render (lighting, relfection, refraction etc.) on top of each other and add them linearily, then optionally also gamma-correct (or view transform it), would you get exactly the same render or not. There are operators which will break this (ACES OT, Tone Curve, etc.) and these operators have this clearly stated in their tooltips. If you are not compositing using layers, you probably don’t want to care about this.
We have checked it earlier, and it seems to be expected. It was not so slow for me, but curves/histogram should process all the values, and display them, so it takes time and can be hardware/system dependent. I have suggested using some optimization (maybe less accuracy), but it is for some other time, if it is decided to improve this. So, as of now, the slow responsiveness may be expected for high resolutions and many operators for curves/histogram to process.
