too many RGB Output files
Hi Guys,
I am wondering if it is possible to control the number of beauty channels´ output.
We are having:
filename._.origRGB.0001.tif
filename._.RGB_color.0001.tif
and finally - if wished:
filename._.VRayDenoiser.0001.tif
and finally, I have to set the common parameter´s render output as well, otherwise, online farms won´t work anyway. Unskippable.
Ok, I can set here a cheap JPG Sequence, but - why!? (that´s of course an Autodesk issue because those functions are the outdated Dinos in 3D max)
The first is not having any differences (in my eyes) but if you keep the output as 16 bit Tif ~12-16 Megabyte each - you always get a tremendous amount of Data with Animations - senseless.
Especially when using a Render service online, there is needless, useless data traffic.
Any Ideas /suggestions, on that?
You cannot disable the saving of the pre-denoised RGB, however, it’s a good idea to have a backup (i.e. if you wish to denoise again with different settings, or other edits). Regarding the common output thing - that’s not something we have control over.
