Too Many Small Bubbles and Cant Wind Them Back
Hey there,
Per the image attached, I am generating tonnes and tonnes of small bubbles and can’t shake them.
I keep changing the B2B settings but then I throw off something else.
B2B - 100
Rising - 17cm
Falling - 170cm
Surface Lock - .5
Happy for there to be some just not SOOO many of them that they take away from the actual look of the flow.
Thanks heaps.
Oh, could it be the B2B that pushed them apart and makes them distribute evenly? I would assume you have Foam patterns turned off?
hey,
I have patterns on .5 and 10cm. When the water flows down the shapes it flattens out in some areas and forms the patterns, just not sure of the B2B and patterns combination to not have the mass of bubbles.
Here is my last example so you can see what I mean.
Ahuuum, wonder if the patterns are not kicking in if the liquid is too shallow. If this is the case, then maybe it’s a matter of raising the foam birth threshold or decreasing the half life. In some areas it really looks like dry ice smoke is moving over the ground.
there is no foam birthing, it is all from splash, so are you saying bump up that amount?
Ah, no no - the opposite - I imagine that with less foam it would look better, so maybe decrease Foam on Hit (or increase the foam Threshold in setups where foam is born naturally).
