Toolbars disappear when using VFB
In sketchup, every time you open or click on the frame-buffer, all the Vray toolbars disappear. To continue working, you have to click off the VFB first before you can click on a tool.
Why disrupt the flow like that ? Can we toggle this “feature” OFF ?
Hi @leotchest ​,
Unfortunately this is the default behavior of SketchUp when you have your toolbars floating (undocked).
Basically when another process is in focus, and the main SU window goes out of focus, all floating toolbars disappear.
The only workaround that I can suggest is to dock all the toolbars you’re using (this does not apply to macOS since there the toolbars can not be docked…).
Regards,
Konstantin
