Toon Base Material
Hello. I am trying to select a different base material in a Toon material. All I appear to be able to do is either select none or select the current base material.
If I ‘edit’ the current base material I can’t see how to get back to the Toon material, so all changes are lost as I can only save the base material.
Any help much appreciated.
V-Ray for Revit 3.60.04
Changing the base material is not supported in the current V-Ray for Revit version. However, it will be available very soon.
Also, please update to V-Ray for Revit 3.70.05, as the version you are using is outdated.
Best,
Ana
