Interesting issue we’ve run into a couple of times… Invisible lights seem to cut toon lines, even when light is behind object.
1) Assign VRayToon to Atmosphere, any settings.
2) Create area light, put behind object. Toggle ‘Invisible’.
3) Render.
Attached is a sample scene reproducing the problem - one object, 2 invisible lights (one hidden). For some reason, the outline of the light cuts out the toon effect. Hiding the light doesn’t seem to fix issue either.
This obviously isn’t a huge problem, but thought I would throw it out there, might be indicative of other issues?
vray_bug_lightToon.zip (20.6 KB)
