This is my first time using the toon material, and I’m not sure why in the render the shadows are flickering. I’m actually confused as to why there are shadows at all, I turned off all cast shadows on lights.
Let me know if you need anything else!
Hi, the approach used with the toon material is slightly different than rendering a realistic image.
You could use this guide as a starting point.
Let me know if that helped.
That was very helpful, thank you!
