toon material with vray?
how can I do it?, I need to highlight the edges of a very white object.
falloff in the diffuse slot?
I´ll try but I don´t think is going to work my object is very boxy, falloff works well with round things
Make a reference of all ur objects, then apply the Lattice modifier with edges only, then apply ur white mat,
and u have a nice toon effect :slight_smile:
If you are using Max 5 the “ink and paint” material works pretty well with V-Ray
You might also try using VRayEdgesTex to mix your edge and field colors.
nice tip PixelJockey I´ll try it thanks, and thanks to all you guys great tips.
