Hi, I know this has sort of been requested, but again, Toon Outlines like Vraytoon would be invaluable, especially for technical type illustrations, like architecture. No need for a sophisticated shader, just the outlines with some vraytoon like settings (thickness, colour, inlusions/exclusions) would be a great start!!
Pretty please…
I agree with you. Please add Toon Outlines.
Asked for this for several years now, but seems like it is very low priority ![]()
But absolutely +1 for this.
BTW - you can vote it up in the “most wanted feature” thread.
I have just made sure that this is correctly reported as a feature request.
(Internal ID=582826598)
+1 to this feature. Just requested it but my feature request got insta deleted due to duplication ![]()
+1
Look at Cebas final Toon : it is a piece of art toon shading. It can even uses hatching for shadows…
Please add that to Corona !
+1 For this.
If corona wire had a way to just do profiles and not all edges it would be absolutely ideal for rendering elevations. Im certain ive seen tons and tons of this same request for the past ten years. If you did it, it would likely make a ton of people very happy!
+1 for this
+1
It’s easily the most requested feature here on the forums, loads of different threads requesting it. Just to clarify to the devs, we’re not looking for a full ‘toon’ setup, we just want a wire shader that handles edges in the same way VRay Toon does and as JP says, one that doesn’t highlight every single edge in the underlying geo.
This is currently logged as a feature request in our system.
(Report ID=CMAX-947)
If it could be logged as a card on trello id be even happier!
Yes this would be a great feature.
Cebas’ FinalToon would be the benchmark and is very powerful, but overpriced IMO if you just want occasional simple ink line renders. FSTorm has a primitive outline render pass you can add, but it’s nearly useless its so limited.
Something in between the two would be quite helpful I think.
+1
Definitely one of the top features I’d like to see implemented in Corona, so … please add it.
I am adding my voice to those of others; this is really a missing feature. Moreover, it was a well-ranked request in the survey you conducted.
