hello
I wonder if it is possible to trace toon edge just for outline object and not for all edges (in lightwave we can for exemple choose : material, creases, outline,.. each with different width ) ??
Have you tried VrayToon? In the environment dialouge?
yes of course…
misunderstanding is due to my bad english,
I mean with Vraytoon, is it possible to trace just object silhouette and not other edges ?
Good question.
I don’t think it’s possible; you could try lowering the two threshold options and see if this gets you what you need, but there isn’t an option for just object outlines only. (correct me if I’m wrong anyone)
You could do it in post using a combination of mattes for each object (multimatte would speed this up) but it’s a somewhat more involved process than a single ‘outline only’ button.
Add it as a wishlist! ![]()
thanks for answer :-)) go to wishlist !!!
