Toon Render Spots
Hi
We are doing a stylised toon render animation using vray and all was going well until these yellow spots persisted to come up on the final render - see image;
http://www.inlightin.co.uk/images/Toon%20Dots.jpg
The spots seem to be created when the sunlight passes through the thin trees which have an opacity.
The irrad and LC maps are pre calculated @ Fixed 8 and -3,0 Irrad and 1500 LC.
As the spots are fixed in the scene as the camera moves past, I am assuming that they are generated when doing the pre calcs. Does anyone have an idea of how to get rid of these ?
N
Have you tried setting the sun to invisible?
Preisler
Yep, turning on the “Invisible” option for the sun should solve this.
Outstanding ! I already had the Sun set to invisible but didn’t have the sun parameter in the Sky material set.
Now it is and the spots have gone - many thanks !
