hello!!! is there a way to use cartoon rendering in corona? thank you for your advice!
Have you played around with the Cel shader at all? Depending on the look you’re after, it’s possible to get a “toon” feel.
Hi Bean,
Corona Lights does not work in “use light”, exclude or include.
Feed to fix…? Using V6.
Thanks. …
Hi Imran, I’m not sure I follow. Can you share an example for me? Thanks in advance
If you’re referring to this section, that is reserved for C4D lights as it’s a native C4D shader. If you need to use Corona lights in there, the workaround would be to make them editable first.
