Toon / sketch / pencil
Hi
I like to use the toon render, but is there a way to make it more sketch/pencil, with extended lines at corners and so on…
Stefan
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=47689
It was more like this…
SketchUp
That is from SketchUp
ehh yes I know, but I use 3dmax and vray
SketchUp
SketchUp support DWG so export the model as a DWG and import it into SketchUp. You’ll need SketchUp Pro soon, but for now the free flavor will work.
I recall that final render has that feature, so I just thougt that Vray also had it :slight_smile:
finalToon works fine with V-Ray, if you have it. From what I remember, you can also get it seprately from finalRender.
