Toon split/double line
I’m working on a scene where it has quite thick lines (20px) and I get this split/double line - is there any way to stop it doing that? I think it’s maybe pushing the overlap threshold too much, but just curious if anyone else has that problem, or if it may be something to do with the mesh itself.
Thanks,
Steve
Try playing around with the Normal Threshold parameter. The toon lines (pixel mode) also depend on the distance from the camera.
Thanks,
surely if it’s set to pixel rather than world, the distance shouldn’t matter? (This was just a crop of larger image, the camera isn’t that close)
It’s the opposite; the distance doesn’t matter if it’s set to ‘world’.
Thanks,
not sure I can eliminate the problem either way - I also tried it in Redshift’s toon renderer and it seemed to have the same issue.
You can try smoothing the geometry.
