ToonLine trace contours from noise maps
Is it possible for the VRay Toon to trace grudge noise maps like in the sample below to help add detailing.
https://refriedspinach.artstation.co…ader-breakdown
https://www.arnoldrenderer.com/news/toon-shader-calder-moore/
Using the VRayToonMtl’s “Mask Color” option (when the Toon effect lines are overridden) should do the trick. Set a texture map for the Mask Color and control the lines through the Mask Color threshold. More information in the technical documentation.
Fantastic, works a treat, thank you.
