Hi, I published my last job.
https://www.360cities.net/image/livingroom-cikrvice
Did you rendered straight in 360x180 or stitched out of separate images? If latter, than what did you used for secondary solver, pt or hd?
I tried once to stitch pano from 6 renders, rendered in pt+hd and found it incredible difficult to render perfectly matching renders due to hd caching.
Damn those are nice! I’d also be interested in hearing your pano setup and how to get around the HD cache issue.
Have you tried saving the HDCache first? Should be working perfectly afterwards. I mean, save hdcache from 1st frame and render the other 5 with loaded Cache.
No, i haven’t. Is hd cache calculated for out of camera view range too? Never thought about it.
yes
Thanks for the compliment. I used really pt + hd. For the living room, I used 64 pt samples and maximum intensity of 400 sample everything else here had the original settings. I used to pano panorama exporter. To clean the stitch I used the Healing Brush.
Do you mean max’s own panorama exporter? In my experience its much inferior than other solutions. I would never use it for any serious job.
