Topography Lines Visible
Status: pending
When we are working on properties with steep slopes, it is helpful to show topography lines in our 3D models. This conveys just how much grade change occurs on the site.
In Revit and Sketchup, our models show topography lines clearly. If we are presenting in Enscape, we do not have this ability.
If we were able to show topography lines in an improved, sleeker artistic setting, we would use Enscape for all presentations.
Submitted on AHA Ideas by Aiden Stevens (ENSCAPE-I-1506).
A different, but very similar issue. The artistic settings get rid of material linework on walls (and roofing, floors, etc) that give the building a sense of scale. For instance, if you have a vertical wood wall in Revit with 6" wide boards, it would very very helpful to see these lines in an artistic setting without having to model the gap between boards in order to get them to show up Enscape. Sure, it’s possible to export multiple view settings and combine them in Photoshop, but this would make the workflow much more streamlined
Submitted on AHA Ideas by Jill Eliason.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
