total sequence time in minutes?
this is a simple question. in the vray message/log window, is there a way to make it spit out the total frame/sequense time in minutes instead of seconds? i always pick up my calculator to do the conversion, and it would be easier, at least for me, if i could just tell it to use minutes.
Isn’t there a ‘total rendering time’ display as a default at the bottom of the Max interface? That one is always in minutes so I look at that instead of the Vray dialogue.
Just check the bottom of 3DS MAX, it will spit it out in hours, minutes, and seconds.
The display at bottom left is only the last frame time. If you want the last sequence time, got to File | Summary Info… and look in the top right section.
