Tranparancy for water? Is there any bugs?
Hey guys . I’ve just done some image related with the water pool.
There shows 3 different problems.
Please CC & comment.
1. First image there’s only reflecting on the water but no transperancy, so the tile pool not showed.
2. Second image is the one that succesfully transperancy and displacement for the water.
3. Third image there’s 2 problem the reflecting not correct and transperancy not worked.
Re: Tranparancy for water? Is there any bugs?
I think beside the transparency settings the viewing angle. For example:
Low angle (less transparency seen)
Large/high angle (More transparency seen)
As for the third problem, is it a default SU material?
Thanks, ;D
but about the angle is it water character naturally?
For third image its the same material water with other image. But the third image model file is the biggest.
Yes, naturally. At least that’s my opinion. The images that i posted below are real world so… it make sense.
In third image i meant the material of the columns witch are reflected in the water. are they have default SU material?
play on the fresnel refelct colors. the white make it darker. see how.
Yes the column paint material from SU material(marker - beige).
Is it make any problem with the SU material, and i’m not linked it to vray material.
Nick, these still look pretty good aside from the water. The second image looks the best to me (as you said). How did you do the water?
Re: Tranparency for water? Is there any bugs?
Thanks 40th and nomerado ;D
I think I’ve already found the problem. It’s on the refraction transparency. Because my water mat was modified from clear glass mat.
And Joe, here’s water material that I modified from clear glass SU , hope it helps ;D
got it good to know
Very kind of you to explain that way. Now it needs caustics and it’s perfect ;D
Nick, thanks for the instructions, I will definitely keep these in my file for future reference.
I try to make good water too, but all I get it’s this…maybe I’m dumb.. :-\
If you try to make the water look more transparent. I think that it’s Refraction IOR interferes with the Reflection IOR.
Yes stafanq 40th is right.
The water seems too dirty, so you need to make the refraction transparency more white.
;D
Yes. thanks guys! I made the water from glass, and it’s seams to be fine now!
Thanks Nick, very usefull and easy to follow this topic!
Love this render… what kinde of settings did you use?
The third picture with the default sketchup material applied to the columns, you need to paint the back sides too (paint the inside faces which is what is seen in the water reflection). The water reflects the backside of the material, in this case, the inside faces of the columns.
