Hello, I don’t quite understand the color space transfer function and was hoping someone could clarify for me. Also, I just wanted to make sure I’m understanding the RGB color space correctly? I think I’ve read that if you rename your files correctly, you could leave it at default rather then always having to change it for the specific map? As always, any help is greatly appreciated!
Color space transfer function
- Not sure…!?
RGB color space parameters
- All color maps would be set to the color space you’re using
- All B&W / Norm / Disp would be RAW?
