I have installed Enscape for Revit, but i also want to use it in SketchUP (On the same machine).
How do i do that if the license was bougth by a previous employer.?
Or do i need a new license for that.?
Hi @Klavs your license contains support of both Revit and SketchUp and uses only one seat for both solutions if they run on the same machine.
If the license is not set already in SketchUp after installing Enscape, you should be able to set it manually.
We can change your license data, especially the connected e-mail address if you want. Please contact us via .
I will try that.
Thanks.
