Hi guys,
I have a problem with transfering my lightmix from the VFB to the scene. I always get the same error:
Error: V-Ray : [VRayMaya::LightMixTransferData::copyTransferSettings] -100: The light setup in the scene mismatches the one in Light Mix
Sebastian
This error means that there is a mismatch between the lights in the Light Mix list mismatches the actual lights in the scene. Usually, this may happen when adding/removing lights. Could you share the exact steps taken for the error message’s appearance?
It’s actually impossible that there is a mismatch and I already checked like a thousand times.
I positioned my lights in the scene, added a lightmix Render Element in the render settings and rendered a frame in the VFB. After the render completed I adjusted the intensity of the lights in the VFB until I achieved the look I wanted. I also saved the lightmix to a lightmix file so I can always come back to those settings.
Once I try to apply the lightmix to the scene the error message described above is displaying…
I get this same error as well. Even on very basic scenes
I cannot seem to reproduce the issue with the mentioned steps. Could you share a video of the reproduction? Could you attach a simple scene as well? Also, which Maya and V-Ray versions are you using?
