Transferring vertex shading from one model to another with reduced polys with Vray projection baking
Simple question, I have a dense scan of a mesh with RGB info in vertex shading. I’d like to transfer the vertex shading as a texture on a reduced model with UV’s. Will VRAY’s baking engine consider vertex shading? Can I pass that into a texture through projection baking? Or is there a better way to do that? Thanks for any suggestions.
Simply apply and bake a VRay User Color texture (set User attribute name to the color set name).
Yes!!! I discovered that node a few days after posting. Thanks for responding.
