Transforming a Map
Hi Volks,
here my question:
Is it possible to transform a Texturemap like shown in the attachement?
I cant find any Mapping Widget Control Points. (pressing F10)
THX for any Help.
Re: Transforming a Map
If you use the UV of a plane and cut the round, than it should match (see image), but the texture will be distorted, the front edge wood texture will be without a constant width. If you need it perfect, you must create a texture for every step - like a cabinet maker. :wink:
Thank you very much, Micha. But i do not understand your solution.
Can u try to explain it easier, if its possible. :-\
Another view.
If u want to make it perfect u have to create a new texture in photoshop or gimp or something for each step.
You could create a plane in the same position like the mapping widget of your last screenshot → turn on control points → manipulate controlpoints → point off → cut the outer edge → one step is ready, the texture should be like expected. This needs be done for each step.
Ahh, THX a lot Micha. Now i have understand it.
Thank bouth of u.
Bye Sanny
