Hi all, I have an issue with a translucent material, if you change the values from 5 to 6 in the slider the properties are very different. Is the yellow roof above in the image. I need something in between but it doesn´t seem possible. When I change the value to 6 it behaves like a transparent material projecting direct light and shadows.
Any recommendation?
Thanks in advance
