I would like to get some advice / help on this.
I am modelling a synthesizer with these drum pads and I would like to put a small led under those pads.
I cant seem to get the balance right (light vs translucency).
How would you guys make the material for the rubber and the light properties?
Here is a reference:
Thanks for all the help
Added: And also, should the led under the pad be a sphere or just a disc?
Here is what I did for a small round button (in the rendering HDRI output is at 0.05, exposure 0, high compr 1).
The light is a 1mm disc, intensity 10.
BUT still my question would be: HOW would you guys make something like this?
I believe it is a matter of using proper IOR, refraction glossiness and/or translucency. Trial and error - as mentioned above. IR could be very helpful!
About the light color - there was a trick to use CoronaColor map inside CoronaLightmtl and adjust HDR values. You can see it here: Juraj's Renderings thread - Corona Common :: Gallery - Chaos Forum (CoronaSolid = CoronaColor now)
