have you ever tried the translucent shader from max?
and with area shadows…
it seems to work, not everything, but… ![]()
best regards
themaxxer
so this is what people keep putting in the wish list saying it doesnt work?
no that is a different one
No, here it does not work. What have you done to make it work?
Using 1.47.03, max material with translucent shader and no effect. Can you post a MAX-file ???
hi baumgore
try to put a map into the shadow-parameter/object shadow map slot…(play with density…)
thomes
