transparency alpha channel
Dearl all,
I just starting playing with the new VRAy for MAC, but I’m not able to give transparency to any of my trees._________________________________________________
I followed the video explanation, but nothing changed.
Any suggestion?
thank a lot
cheers Giovanni
Re: transparency alpha channel
What file format is your tree texture?
I used .PNG tree
Can you post a sample texture?
Is the transparency missing when you render - or just in the preview?
The preview isn’t completely reliable.
Problem solved.
Thank you very much
cheers
And what was it?
Other might benefit from knowing your solution.
Simple,
many trees has a wrong alpha channel so I had to save it again with PS.
