Transparency Map problems
I can’t figure out why the transparency on the maps isn’t working. I have set the bitmap blur values to .01. If I switch over to scanline it works fine. Worst case scenerio is to just render the trees with scanline and then comp them in.
Hi
can you share that file ?
