Transparent but NOT translucent = opaque Wall (cast shadows and bounce light but see through)
This is a followup to a “somehow” solved question at the autodesk revit forum:
I’m look for a way to visualize interiors where you can see through certain walls or ceilings (mostly outside walls) but (sun-) light is blocked and bounce back. If I cut the model with a section or scope box the room is lit as if all sunlight comes from the cut areas (which is not realistic).
I tried to create a 100% transparent but 0% translucent material but this does not work as expected (I only want to see the light coming through the windows and glass door and in the rendering the light bouncing from the “invisible” outside wall.
Overriding the transparency by view of the wall does the trick only in realistic view:
This is ignored in enscape. So how to do the same effect in enscape?
Any help appreciated.
@harpie_c , welcome to our Forum and thanks for your post.
I’m afraid, we do not receive the actual updated geometry information by Revit itself which would result in the same output compared to the realistic view in Revit when section boxes are being used. This is why our hands are a bit tied here. You can of course still always hide any objects you like, individually per view as well, so even walls and such could be made invisible this way too.
Thank you for your reply.
Hiding walls or ceilings is not the problem. My task is to have transparent (see through) ceilings or Walls which still blocks the sunlight (or lights from other sources) and cast shadows.
See shadows of the window and door on the back wall cast by the “hidden” facade wall.
So it would be great to define a material which is transparent but NOT translucent and still diffuse reflects light (according to the color and other properties).
Try a creating a material with cutouts using a very small black/white checker texture, I made curtains that way en looks ok
