Tree reflection in glass material
Hello, fellows.
It seems that the Enscape trees do not reflect correctly. I’s like the reflection contains the contour of the 3d object.
I wonder if anybody else has this problem.
reflection
HsDQD9S.html (7.41 KB)
](Imgur: The magic of the Internet)
Cheers. :slight_smile:
Actually it is, I have noticed it now :wink:
Btw. you have cool glass.
Will you enter the settings parameters?
Sure.[
MicojD4.html (7.41 KB)
@Zenoardelean and @Tikos , reflections of trees and generally vegetation is highly simplified to reduce performance cost. Otherwise, if we were to render them in reflections as is, it would be very likely that you would experience some lagging, even if you’d be using a decent graphics card. :slight_smile:
We constantly strive to enhance our real-time reflections in general, and with hardware getting better and better, we’re able to add further improvements which make them look even better and more realistic.
Thank you very much @Zenoardelean , I was too dark “surface color”, that’s why your glass looked better :slight_smile:
How can you make the reflection of the tree on the glass?
My model is just reflecting the trunk and branches. Even, the shadow from the tree is without the leaf.
Could someone please help me out with this?
Try to increase the reflection in the glass.
Use the guide: https://enscape3d.com/knowledgebase/materials-in-archicad/
Alternatively, try the materials from the shared file: Archicad materials for Enscape
And why do not you use trees from the Enscape library? They are much better than those from Archicad :thumbsup:
I know but trees in Assets library does not have 2D appearance. Might be in the end I will use it but in this phase we need to have the relation with floorplans.
Anyway, thank for the advise. I will try see if it fixed.
And how about the shadow, do you know what is happening?
I think the leaves are too small and the shadow from them is blurred
As stated already regarding the missing reflections of your leafs in general, that is a normal behavior to improve performance / avoid performance culprits. Our shadows are not limited in such a way, in this case it looks like the leafs are indeed too small to be really visible in them. :slight_smile:
Like @Tikos mentioned, our asset library trees do in fact look quiet a lot better than the provided ArchiCAD trees, so as soon as you get chance, I recommend to use them to improve your project visually.
Thanks for your advice!
Hopefully Enscape will develop further more advance funtioncs for Archicad.
@thinhpham , anything specific you’re talking about? :slight_smile: Generally, we’ll implement the dedicated material editor which is already available for SketchUp into ArchiCAD as well in the near future, so stay tuned for that. If there is anything else you’d like to see implemented, please kindly let me know.
I have gone through our forum and I aware of everyone has indicated all the issues that we are encountering with archicad. Besides the material editor, it would be really nice if Enscape can incorporate with Archicad about 3d & 2d trees functions.
I am looking forward to seeing the news.
Thank you
Pardon, could you kindly elaborate on that? We plan to add a lot more trees in general into our Asset Library, since they are all in 3D so far, I can also file a feature request to include 2D trees in the future. If something is missing regarding our tree assets, please kindly let me know as well. We’re always open to feedback! :slight_smile:
As you know, in BIM software like Revit and Archicad, they have tree library that can represent both in 2d and 3d. The incorporation between 2d and 3d in BIM software is essential. It reduces working time for designing and organising. At the moment, if I want to use trees from Enscape, I only use it for 3d (visualization). for 2D, it is from archicad.
What I mean is that if I place a 3D tree from Enscape into Archicad, the position of this tree must appear on 2d drawing. That is the ideal situation for what I suggest.
Thanks you.
Agreed
What I would like from the Enscape trees is as follows:
-Place asset object in archicad - archicad object is a simple tree object a ball on a stick like a lollipop - keeps the archicad model running fast
  • Archicad object needs to have capability to add tree specification data to be useful as a BIM object
-Archicad object has a simple plan 2d view, a circle with a dot in the middle - this is typically how we identify proposed trees on a plan
  • option for a second tree symbol to denote existing trees
  • The rendered tree shows up in Enscape render view / vr etc
  • It would be useful if the tree object could have 4 seasonal variations
We are about to start work on an ArchiCAD tree object which does everything we need it to form a BIM perspective and ideally we would like to be able to link that to the Enscape render trees, we’d be happy to work with you on this.
Thank you very much for the valuable feedback @thinhpham and @simonbell , I’ll add it to the corresponding existing and new feature requests I’ll file accordingly. :slight_smile:
I know that in Revit they have RPC object which is really powerfull (working performance and efficiency) and helpful for visualisation. I hope that Enscape and Archicad can work on this to provide more stronger ability for us.
Thank you.
