Tree’s leaf - translucency
Hi guys,
I was just wondering - if I have a tree with a translucency map, should I put into the Corona materiał under Translucency under:
Texture below Fraction
Texture below Color?
If below the Color, should I leave Fraction by default (50%)?
Hi, generally what I do is copy my diffuse texture and put it in the trans color slot with a filter to color correct. Fraction wise, you won’t need much, keep it under 30 or less. So some tests until you’re happy with the look. :wink:
Thanks! I will do tests then with color correction and Fraction below 30 :).
