is the current vegetation 651 items all there is? can you add others if so where from ad how?
Links to resources for materials, lighting, entourage, planting and more. https://blog.enscape3d.com/free-resources-for-architectural-projects
Thank you Phil, do you by any chance know anything about the lighting portion? I have a material set to be self illuminated.. however, it only works about half the time in renders.. it’s super irritating! I can have the material literally right next to each other on two identical objects.. one will be producing light the other will not.. I am in the middle a huge project and I need to get these renders out but I can not fix this issue and it has been an issue since day one.
I wouldn’t use self illumination for a regular light source - more for accent lighting, recessed lighting, screens, etc where a light object isn’t natural enough.
For example, for the pendant light, I’d use a light object but also give the filament self-illumination, to create a natural hot spot. But for the long linear light above the cook top I’d likely just use a self-illuminated material for the white lens above the back splash of the cooktop.
Can you post an image of your condition? It doesn’t take a lot of self-illumination to become apparent. And if you set the value too high it doesn’t read properly. Try a value of 100 to start. IMO the default value is too high.
Thank you Phil!
great job! how did you make the glass cover? very realistic. Can you show the settings?
The images above are photos that illustrate real-world. ![]()
