Hi
I have placed some 3d trees using scatter.
When I zoom out, the trees becomes white, when zoom in, they look ok.
Is there a way to void this, as it spoils my illustration.
Jorgensen
Is the background of the leavesā texture white? If yes, itās a texture filtering issue and you can fix that by replacing the white background with an average of the leavesā color.
@Clemens_Musterle can i send you the tree to test?
Jorgensen
@Jorgensen_dk , have you already followed the guide of @Clemens_Musterle , in case the background of the leavesā texture is actually white? ![]()
Should the texture in fact not be white, then you can just upload the tree here and post the download link afterward. Thank you in advance!
The tree is made of faces with images attached, and looks ok on both sides.
I canāt upload the model, as I donāt remember if itās a paid model.
I have attached two images of the tree, one in sketchup and one in Enscape.
Jorgensen
Try selecting the leaves texture and changing the āTypeā in the Enscape materials dialogue to āfoliageā (rather than āgenericā).
Might not make a difference, but should look a little bit prettier.
Hey @Jorgensen_dk , to make your tree not appear white in the distance, you can do the following:
Export the leaf texture as .png image file through SketchUp directly
Make a copy of that just saved leaf .png image file
Open that copy with an image editor (Paint.NET, Photoshop, etc.)
Now youāll see that the background of that leaf image is transparent = displayed as white in Enscape from a distance
Replace the transparency with an average green leaf color (already edited leaf image can be found attached to my reply)
Save the image as a .jpg file (we donāt want to make use of any transparency information .png would provide for this file)
Open the āEnscape Materialsā editor of Enscape, select the leaf texture via SketchUp
Go to the āAlbedoā tab and import your leaf image with the now green background
Now, for the transparency (mask) go into the General tab, click the ā+ā symbol under āTransparencyā and import the original saved .png leaf image from step one
Let me know if something is unclear to you.
Iāve also send you the project file in which everything is setup accordingly as well. ![]()
Thanks @Demian_Gutberlet
I will try that ![]()
Jorgensen - this āthingā interests me too - can this tree be shared also for me somehow? I would like to follow GadgetĀ“s and Demian GutberletĀ“s instructions for some practice ā¦
