Trial Installation fails
Hey guys,
I just downloaded the Trial version of Enscape. I tried to install and deinstall it several times without any success. It always says “Note: The Installation may require a restart to ensure that Enscape is functioning properly”. If I press “Restart now” my Laptop does a restart, but the Enscape Installer also closes automatically and I have to start the installation again. If I just press “done” the Window closes directly and I also have to start over again.
I also tried different languages, but its always the same issue
What can I do to properly install Enscape?
Hey @Lelehaha
Welcome to the Enscape forum!
Please be aware that Enscape is a plugin, not a standalone software. So after the installation it should show up in your Rhino interface. If it doesn’t, can you please check if you can enable it in Rhino as described here?
https://learn.enscape3d.com/blog/knowledgebase/enable_enscape-win-rhino/
Hey Kai,
thanks for your reply.
Unfortunately the plugin doesn’t show up in Rhino. I can also not enable it, because it’s not shown anywhere. I tried it several times yesterday but without success.
Do you have another tipp?
What version of Rhino are you installing this in?
