Triplanar doesnt seem to work in displacement slot
The triplanar map seems to not have any effect in the displacement slot.
Max 2018, Corona 3
Could you show some examples? Last time i checked, triplanar certainly did work in displacement slot. It may not give desired result due to “odd” order of operation, but it works nonetheless.
It could just as much be an AO map issue. Ill do some tests this week in a clean scene but if i plug in the bitmap directly it works, plug it into the triplanar and then into the slot and theres no displacement at all.
