triplanar on meshsphere
Hi there,
I stumbled on something, i do not understand and wanted to get some help.
So i testing triplanar on a spherical geometry, and getting issues with using on a mesh sphere.
See rendering attached.
First is a regular nurbs sphere. (from left)
second is the same nurbs sphere converted to mesh.
third is a meshsphere (triangles)
fourth is a meshsphere (Uv)
last is meshsphere quad.
All rendered with the same material(just grey with a triplanar normal map on)
Do you know where Mesh (triangle) and Mesh (Quad) doesn’t get the triplanar normal map?
best
Hello @citro3101 ,
Tri-Planar mapping and also any texture mapping will work properly with V-Ray if you apply a Spherical mapping (from Rhino Properties > Texture Mapping) to the Mesh Sphere with Triangles and Quad Style.
Kind regards,
Iva
Thank Iva,
The reason i wanted to apply triplanar on a “blob” not sphere, but yes it works If I create an UV map on them, just wondering why the other mesh types takes on triplanar without adding an UV.
